tyre pressures
tyre pressures
Re: trye preasure
data is a wee bit out though according to the handbook
Re: trye preasure
Wrong data for my beamer
Re: trye preasure
i did think it was a bit low for a v6 cali
what is the correct tyre preasure for a v6 with 17" alloys or does the size of wheel not matter
Re: trye preasure
was too high for mine even on full load...and yes it matters
no idea for a V6 but I run 32 back 32 front
Re: trye preasure
Mmm while on the subject, As you know tyre pressures on a 4x4 are more important, so would I run a higher pressure at the front to overcome engine weight or does it not matter?
Im running 32 all round at the moment.
Re: tyre pressures
The GM Technical Reference Guide 2002 says for Turbo
F 40 R 38 or full load 42/49
OR
F 33 R 30 or full load 34/42
For V6
F 38 R 34 full load 39/48
OR
F 34 R 31.5 full load 36/45
So yes, run higher pressure in front tyres unless there is a heavy load in the back.
OR
For V6
OR
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: tyre pressures
cheers grey
Re: tyre pressures
and that's for 16 wheels
Re: tyre pressures
all services i do at work i use 32psi, espically when you look at it this way,
what temp is it on the day of testing? do you adjust accordingly?
i watched a psi monotring system on a insignia going down the road and i a 3 mile road test it went up 5 psi all round!
i really dont think 2psi here or there makes a big difference
- Club Member
Re: tyre pressures
mmm, i will change the turbo to 34/32 as the sub box in the boot weighs a ton.
having 32 all round does seem to be wearing evenly though.
Re: tyre pressures
i run 34 front ,31 rear
Users browsing this forum: No registered users and 80 guests
