tyre pressures
tyre pressures
by big_gordy » Wed Jun 01, 2011 8:43 pm
i found this and thought it may be handy to even make it a sticky
http://www.tyre-pressures.com/
Re: trye preasure
by Fraz » Wed Jun 01, 2011 9:07 pm
data is a wee bit out though according to the handbook
Re: trye preasure
by RobbieV » Wed Jun 01, 2011 9:08 pm
Wrong data for my beamer :!:
Re: trye preasure
by big_gordy » Wed Jun 01, 2011 9:19 pm
i did think it was a bit low for a v6 cali
what is the correct tyre preasure for a v6 with 17" alloys or does the size of wheel not matter
Re: trye preasure
by Fraz » Wed Jun 01, 2011 9:54 pm
was too high for mine even on full load...and yes it matters
no idea for a V6 but I run 32 back 32 front
Re: trye preasure
by Callyman » Wed Jun 01, 2011 10:01 pm
Mmm while on the subject, As you know tyre pressures on a 4x4 are more important, so would I run a higher pressure at the front to overcome engine weight or does it not matter?
Im running 32 all round at the moment.
Re: tyre pressures
by GreyDJ » Thu Jun 02, 2011 12:47 am
The GM Technical Reference Guide 2002 says for Turbo
F 40 R 38 or full load 42/49
OR
F 33 R 30 or full load 34/42
For V6
F 38 R 34 full load 39/48
OR
F 34 R 31.5 full load 36/45
So yes, run higher pressure in front tyres unless there is a heavy load in the back.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: tyre pressures
by big_gordy » Thu Jun 02, 2011 9:56 am
cheers grey :clap:
Re: tyre pressures
by Fraz » Thu Jun 02, 2011 12:43 pm
and that's for 16 wheels
Re: tyre pressures
by Callyman » Thu Jun 02, 2011 5:41 pm
Dont you think 38 is a bit high?
Re: tyre pressures
by stevo turbo » Thu Jun 02, 2011 6:06 pm
all services i do at work i use 32psi, espically when you look at it this way,
what temp is it on the day of testing? do you adjust accordingly?
i watched a psi monotring system on a insignia going down the road and i a 3 mile road test it went up 5 psi all round!
i really dont think 2psi here or there makes a big difference
Re: tyre pressures
by Callyman » Thu Jun 02, 2011 6:06 pm
mmm, i will change the turbo to 34/32 as the sub box in the boot weighs a ton.
having 32 all round does seem to be wearing evenly though.
Re: tyre pressures
by BazV6er » Wed Jun 08, 2011 7:55 am
i run 34 front ,31 rear
Users browsing this forum: No registered users and 45 guests
