I have a faulty abs sensor.
by Proxie » Thu Oct 06, 2005 2:11 am
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->Its the 29 tooth type please [img]/smile.gif[/img] .................... please tell me you have at least one.<!--QuoteEnd--></div><!--QuoteEEnd-->
Give me a couple of days.. I'll check it out (pile off spare parts, some at my friends place [img]/smile.gif[/img])
Proxie
by AndiSe5 » Thu Oct 06, 2005 8:30 pm
Thanks again.
Fingers crossed.
AndiSe5
by swchoi » Fri Oct 07, 2005 11:32 am
vauxhall doesn't sell this anymore?!! Mine was disappered somehow maybe it was too rusty and cracked.
swchoi
by Sackie » Fri Oct 07, 2005 3:20 pm
<!--QuoteBegin-Kieran_Burns+--><div class='quotetop'>(Kieran_Burns)</div><div class='quotemain'><!--QuoteEBegin-->carb cleaner and a polish on the crowns should sort you then - I had the damn' light flashing on mine after every bout of crappy weather... it got predictable in the end<!--QuoteEnd--></div><!--QuoteEEnd-->
I have a similiar problem, could I just use WD40??
I only ask as I have no carb cleaner and cant be arsed to go to the shops [img]/wink.gif[/img]
Sackie
by Sackie » Fri Oct 07, 2005 3:22 pm
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Is rust realy such a big problem in the UK? I've never seen an ABS ring look that bad! :eek:<!--QuoteEnd--></div><!--QuoteEEnd-->
Good old english weather, plus the sea air gets around abit, youve only got one coast, were an island
Sackie
by AndiSe5 » Sun Oct 09, 2005 10:29 am
Any luck with finding me a part Proxie ?
AndiSe5
by Proxie » Mon Oct 10, 2005 2:19 am
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->Any luck with finding me a part Proxie ?<!--QuoteEnd--></div><!--QuoteEEnd-->
Damn it... forgot it this weekend :duh:
But I'm 99% positive that I have this ring/s
Drop me an email at
Proxie
by Fraz » Wed Oct 12, 2005 10:12 am
not sure if this is the right one
<a href="http://cgi.ebay.co.uk/Vauxhall-Cavalier-ABS-Sensor-Ring-p-n-90216274_W0QQitemZ4547264059QQcategoryZ10404QQssPageNameZWD1VQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/Vauxhall-Cavalier-AB...1QQcmdZViewItem</a>
by AndiSe5 » Wed Oct 12, 2005 5:34 pm
Thanks fraz, ive asked him if its the 29 tooth type, if it is then you get a BIG gold star.
AndiSe5
by Red_Calibra » Fri Oct 14, 2005 7:27 pm
Sorry to gatecrash the thread fellas, but I'm getting an intermittent flickering of the ABS light and had a look underneath at the rings. Although I cant be 100% sure that there's no cracks, they all look very rusty and worn like that one in the first picture.
I was wondering what was involved in removing them and fitting new ones?
Also, Andi, as well as the ABS light coming on, did you find at any point, that the ABS "kicks in" for a second when you are braking after you have first started the car and driven a few yards down the street? Mine does.
Got a mate with a Tech 2, I should really either get him to check it out or grab a paperclip I 'spose!!
Red_Calibra
by AndiSe5 » Fri Oct 14, 2005 8:36 pm
Yes those were the symptions.
The rings are not replacable as there not made for the 29 tooth type.
But they can be cleaned.
AndiSe5
by Red_Calibra » Fri Oct 14, 2005 10:12 pm
They're not replaceable? Bugger.........!!!
Hope I can just clean mine up then, they look rusted to hell tbh.
Red_Calibra
by breeze » Sun Oct 16, 2005 10:21 am
AndiSe5, how did you find out your ABS wasn't working - the light on the dash?
breeze
by Peruzzi » Sun Oct 16, 2005 2:31 pm
My abs light is on aswell. I had it plugged into a machine at the garage and its come up "ABS sensor, left front".
Mechanic said the sensor is about £50, is that about right?
Peruzzi
by AndiSe5 » Sun Oct 16, 2005 7:42 pm
Breeze, yeah the light came on and off so decided to check out the fault using the paperclip method. Anyway went to clean the rear sprockets and there was a massive crack in it one.
AndiSe5
