I have a faulty abs sensor.
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->Its the 29 tooth type please [img]/smile.gif[/img] .................... please tell me you have at least one.<!--QuoteEnd--></div><!--QuoteEEnd-->
Give me a couple of days.. I'll check it out (pile off spare parts, some at my friends place [img]/smile.gif[/img])
Proxie
<!--QuoteBegin-Kieran_Burns+--><div class='quotetop'>(Kieran_Burns)</div><div class='quotemain'><!--QuoteEBegin-->carb cleaner and a polish on the crowns should sort you then - I had the damn' light flashing on mine after every bout of crappy weather... it got predictable in the end<!--QuoteEnd--></div><!--QuoteEEnd-->
I have a similiar problem, could I just use WD40??
I only ask as I have no carb cleaner and cant be arsed to go to the shops [img]/wink.gif[/img]
Sackie
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Is rust realy such a big problem in the UK? I've never seen an ABS ring look that bad!
Good old english weather, plus the sea air gets around abit, youve only got one coast, were an island
Sackie
AndiSe5
Sorry to gatecrash the thread fellas, but I'm getting an intermittent flickering of the ABS light and had a look underneath at the rings. Although I cant be 100% sure that there's no cracks, they all look very rusty and worn like that one in the first picture.
I was wondering what was involved in removing them and fitting new ones?
Also, Andi, as well as the ABS light coming on, did you find at any point, that the ABS "kicks in" for a second when you are braking after you have first started the car and driven a few yards down the street? Mine does.
Got a mate with a Tech 2, I should really either get him to check it out or grab a paperclip I 'spose!!
Red_Calibra
