Does DIII mix with DII pas oil?
by gremlin » Wed Apr 13, 2005 10:01 am
I put some DIII oil in to top up the PAS and realised after adding a bit that i should be using DII. Will this casue much of a problem will they mix or do i need to drain and fill again?
gremlin
by Dan Willis » Wed Apr 13, 2005 10:04 am
I don't know the difference... but if it were me I'd drain and refill.
Dan
by Rusty_CallyT » Wed Apr 13, 2005 11:01 am
why not just use DIII? im draining mine and refilling with DIII as my fluid has gone a rather nasty colour
Rusty_CallyT
by Dan Willis » Wed Apr 13, 2005 11:07 am
Yeah I'd agree there.. not a hard job (just messy).
Dan
by Stupink » Wed Apr 13, 2005 11:29 am
I think they mix ok.
But unless its nice and clear red, then its a good excuse to get round to a full change [img]/smile.gif[/img] altho, i think you've done this recently anyway from your other post?
by steve3000 » Wed Apr 13, 2005 3:02 pm
How's the best way to drain 4x4 pas then?
I took a look the other day - guessing it'd be best to pull the rubber pipe from the PAS pump off where it joins the metal pipework under the radiator??? just looks very fiddely aronud there with the a/c pipework etc... Any better suggestions?
Steve
by Stupink » Wed Apr 13, 2005 4:51 pm
Pas pump is the lowest point so yeh, the best place im afraid.
by gremlin » Wed Apr 13, 2005 6:09 pm
Whats the difference between DII and DIII? Does it have to be DII?
gremlin
