koni suspension
koni suspension
looks massive compared tot he suspension i have
thing is, the suspension is compressed?? and doesnt seem to let its self out stright, is this normal??
Cheater2k
put konis on yesterday and the mechanic(part time rally driver) took my car for a couple of laps around morrisons supermarket, the store is sorrounded by a 1 way road with chicanes tight corners and a hairpin. i had never heard my car or seen it being driven before never want to again but setting 2 turns on the front and 2.5 on the back is as good base setting
dj_smurph
nuts
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->yeah, the nut doesnt go on loads
although for some reason on the front, once side sits a little higher??<!--QuoteEnd--></div><!--QuoteEEnd-->
as every one has this problem, why dont every one complain to the manufactures? plus all kits should come with camber correction kits, esp for the 4x4, what about using those well expensive coilovers? any one fitted those? results?
akuma
but if every one started returning their products they would have to take note. and as all money loving companies go. they'd do anything to make money on it.
" the new and improved lowering kit for the calibra, same as the old one. but with the adjustments we should of done in the first place
yours for only!
£800"
you know they jus would
any way i jus got my camber kit trough from wallace. how do i go about fitting it? no instructions included. what tools do i need?
thanks
yours for only!
£800"
thanks
akuma
