koni suspension
koni suspension
by Cheater2k » Fri Oct 07, 2005 12:37 pm
looks massive compared tot he suspension i have
thing is, the suspension is compressed?? and doesnt seem to let its self out stright, is this normal??
Cheater2k
by Cheater2k » Fri Oct 07, 2005 12:40 pm
checked the numbers and its right [img]/smile.gif[/img]
just wondering what its not dampering properly?? or do i need to set the tops for it to work?
Cheater2k
by AndiSe5 » Fri Oct 07, 2005 5:03 pm
Ive just got konis to along with a work mate and thay are huge.
If you can pull the shock out and in with no jurky movement there ok.
AndiSe5
by Cheater2k » Fri Oct 07, 2005 6:29 pm
that sounds about right [img]/smile.gif[/img] right then, im gonna go fit them [img]/smile.gif[/img]
Cheater2k
by AndiSe5 » Sat Oct 08, 2005 5:30 pm
Just fitted mine and am delighted [img]/smile.gif[/img]
How did you get on ?
Ps the nut doesnt seem to go on to far on the strut top, is it the same with you ?
AndiSe5
by Cheater2k » Sat Oct 08, 2005 6:59 pm
yeah, the nut doesnt go on loads
although for some reaosn on the front, once side sits a little higher??
im just hoping setting them all to soft, then let them settle as at the moment all 4 could be different.
Cheater2k
by AndiSe5 » Sat Oct 08, 2005 11:28 pm
All for are the same height as they were before (-30mm) but i have mine set to hard [img]/smile.gif[/img] and boy is it hard.
AndiSe5
by Cheater2k » Sat Oct 08, 2005 11:31 pm
mines all on soft and its still wrong, ive also tried it on hard, only thing i can think of is it must be the springs.
Cheater2k
by AndiSe5 » Sat Oct 08, 2005 11:43 pm
Surly they cant be sat rite in the cups etc. Strange though.
There is a specific way you must sit the spring on the top that it shows in the hayns.
AndiSe5
by Cheater2k » Sat Oct 08, 2005 11:47 pm
ive done all right mate, its sat in all the right groves, and where the old springs was (my old shocks are really ****ed to (leaking oil) so i cant even fit those )
Cheater2k
by dj_smurph » Sun Oct 16, 2005 9:43 am
put konis on yesterday and the mechanic(part time rally driver) took my car for a couple of laps around morrisons supermarket, the store is sorrounded by a 1 way road with chicanes tight corners and a hairpin. i had never heard my car or seen it being driven before never want to again but setting 2 turns on the front and 2.5 on the back is as good base setting
dj_smurph
nuts
by akuma » Mon Oct 24, 2005 8:59 am
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->yeah, the nut doesnt go on loads
although for some reason on the front, once side sits a little higher??<!--QuoteEnd--></div><!--QuoteEEnd-->
as every one has this problem, why dont every one complain to the manufactures? plus all kits should come with camber correction kits, esp for the 4x4, what about using those well expensive coilovers? any one fitted those? results?
akuma
by Cheater2k » Mon Oct 24, 2005 9:03 am
true, but there doing there job right, its lowering the car and improving handleing, there not arsed about tyres and wot not
Cheater2k
by akuma » Mon Oct 24, 2005 1:29 pm
but if every one started returning their products they would have to take note. and as all money loving companies go. they'd do anything to make money on it.
" the new and improved lowering kit for the calibra, same as the old one. but with the adjustments we should of done in the first place
yours for only!
£800"
you know they jus would
any way i jus got my camber kit trough from wallace. how do i go about fitting it? no instructions included. what tools do i need?
thanks
akuma
