Which Suspension
Which Suspension
by ice » Sun Apr 02, 2006 1:36 pm
Im looking at changing my suspension next week but not sure which 1 to go for. Im ponding over the following:
1) Bilstein
2) Spax
3) Koni
Is it worth getting the coil overs?
Is it worth getting the camber kit?
Where is the best place to get the kit from?
Im changing also at the same time.
1) Wishbones ( complete with bushes and ball joint )
2) Drop links
Cheers for the advice in advance
Stu
[img]/smile.gif[/img]
ice
by nigescalli » Sun Apr 02, 2006 2:23 pm
i would say bilstein set up camber kit would say yes and wishbones and links would also say yes unless there alright
nigescalli
by Welsh_Andy » Sun Apr 02, 2006 5:22 pm
well i got the koni kit and think its awesome,but the bilstein kist are good too.
but if your gona get a full kit,check who makes the springs for bilstein, as koni changed to Roc from vogtland,personally aint tried the roc srings but the vogtlands had a gd rep
Welsh_Andy
by dj_smurph » Sun Apr 02, 2006 7:18 pm
coil overs start at 450 for fk but can go over 1200 for the calibra because of the rear suspension, i would recommend the koni kit as any vauxhall i have sat in with a koni kit on it made the car handle like it should,
the camber correction kit a must, powerflex is the cheapest iirc as it will protect the transfer box
change all the bushes for powerflex you will have a car that sticks to the road
dj_smurph
by ice » Mon Apr 03, 2006 12:11 am
will i need a camber kit even if im only lowerng the car by like 35mm?
ice
by vibein » Mon Apr 03, 2006 12:21 am
<!--QuoteBegin-ice+--><div class='quotetop'>(ice)</div><div class='quotemain'><!--QuoteEBegin-->will i need a camber kit even if im only lowerng the car by like 35mm?<!--QuoteEnd--></div><!--QuoteEEnd-->
You better believe it unless you like forking out for tyres every few months, and also forget about 4x4 holding up for long.
vibein
by ice » Mon Apr 03, 2006 12:24 am
ar ok bugger
ice
by ice » Mon Apr 03, 2006 8:41 am
Where is the best place to get a camber kit and roughly how much is it?
ice
by dj_smurph » Mon Apr 03, 2006 5:39 pm
powerflex do the bushes -demon tweeks? cheapest bushes
wallace performance is about £125
irmscher is about £200
dj_smurph
by ice » Mon Apr 03, 2006 7:46 pm
125 is better than 191 lol and that was from autovaux
ice
by ecosseM » Mon Apr 03, 2006 9:02 pm
av just fitted Bilstein's(sprint) with eibach springs, not to hard and handles nice.. last calibra had g'max kit with camber kit, sat and handled nice to, only reason got billies etc on now is a good buy of ebay
ecosseM
by ice » Mon Apr 03, 2006 10:26 pm
ecossem do you have the camber kit with the billies?
ice
by ice » Mon Apr 03, 2006 10:30 pm
oh and where did you get them from? private buyer or retailer on ebay?
ice
by ecosseM » Mon Apr 03, 2006 10:36 pm
no, wheels look like sitting ok.. the thing about the camber kits is.............. finding someone with a 4 wheel camber setup system, ad look into that one before you jump in and get one fitted. i fitted onto old calibra because when fitted the gmax kit is sat on its arse and made both rear wheels scub alot.. i actualy ended up with regal rear springs with a 20mm drop, coz with the camber kit on, it can iether raise or lower the car when set
ecosseM
by ice » Mon Apr 03, 2006 10:42 pm
my local tyre dealer has the 4 wheels lazer tracking and camber adjustment system they did my corsa before as it had camber adjusting bolts on the front....
the reminds me [img]/smile.gif[/img]
Courtenay sport ill give them a buzz in the morning i always get a good deal from there lol
how much did you pay for your billies?
ice
Users browsing this forum: Majestic-12 [Bot] and 15 guests
