Which Suspension
Which Suspension
Im looking at changing my suspension next week but not sure which 1 to go for. Im ponding over the following:
1) Bilstein
2) Spax
3) Koni
Is it worth getting the coil overs?
Is it worth getting the camber kit?
Where is the best place to get the kit from?
Im changing also at the same time.
1) Wishbones ( complete with bushes and ball joint )
2) Drop links
Cheers for the advice in advance
Stu
[img]/smile.gif[/img]
1) Bilstein
2) Spax
3) Koni
2) Drop links
Stu
ice
coil overs start at 450 for fk but can go over 1200 for the calibra because of the rear suspension, i would recommend the koni kit as any vauxhall i have sat in with a koni kit on it made the car handle like it should,
the camber correction kit a must, powerflex is the cheapest iirc as it will protect the transfer box
change all the bushes for powerflex you will have a car that sticks to the road
dj_smurph
<!--QuoteBegin-ice+--><div class='quotetop'>(ice)</div><div class='quotemain'><!--QuoteEBegin-->will i need a camber kit even if im only lowerng the car by like 35mm?<!--QuoteEnd--></div><!--QuoteEEnd-->
You better believe it unless you like forking out for tyres every few months, and also forget about 4x4 holding up for long.
vibein
no, wheels look like sitting ok.. the thing about the camber kits is.............. finding someone with a 4 wheel camber setup system, ad look into that one before you jump in and get one fitted. i fitted onto old calibra because when fitted the gmax kit is sat on its arse and made both rear wheels scub alot.. i actualy ended up with regal rear springs with a 20mm drop, coz with the camber kit on, it can iether raise or lower the car when set
ecosseM
my local tyre dealer has the 4 wheels lazer tracking and camber adjustment system they did my corsa before as it had camber adjusting bolts on the front....
the reminds me [img]/smile.gif[/img]
Courtenay sport ill give them a buzz in the morning i always get a good deal from there lol
how much did you pay for your billies?
ice
Users browsing this forum: Bing [Bot] and 4 guests
