My callys just to stiff
Hi guys , my cally is lowered 60mm on standard shocks, prob is i love the look of the car but its just far to stiff. Looking at poss suspension change ( on a budget tho! ) has anyone tried any kits with that amount of lowering? I know if i went for a 30mm kit it would be better but dam its looks good as it is!!!
ollie
<!--QuoteBegin-ollie+--><div class='quotetop'>(ollie)</div><div class='quotemain'><!--QuoteEBegin-->Hi guys , my cally is lowered 60mm on standard shocks, prob is i love the look of the car but its just far to stiff. Looking at poss suspension change ( on a budget tho! ) has anyone tried any kits with that amount of lowering? I know if i went for a 30mm kit it would be better but dam its looks good as it is!!!<!--QuoteEnd--></div><!--QuoteEEnd-->
60mm on standard shocks,sheesh u asking for probs,if u lower more than 35/40mm shortened shocks are needed
u get what u pay for in the end
Welsh_Andy
<!--QuoteBegin-chief+--><div class='quotetop'>(chief)</div><div class='quotemain'><!--QuoteEBegin-->but would'nt uprated shocks be worse than standard ones??<!--QuoteEnd--></div><!--QuoteEEnd-->
If the standard ones are worn or bust, no.
If the aftermarket ones are progressive or adjustable, no.
If the aftermarket ones are badly matched to the springs, yes.
You can get softer springs that are the same ride height but the softer they are the more your gonna bottom out. On my escort I had a gmax kit and then split fire things rammed in the springs to stop the tyres rubbing in the arches. It would rattle your fillings out!! [img]/biggrin.gif[/img] Handled nicely until you hit a bumpy bit of road. LOL. [img]/biggrin.gif[/img]
