My callys just to stiff
by ollie » Thu Apr 06, 2006 6:13 pm
Hi guys , my cally is lowered 60mm on standard shocks, prob is i love the look of the car but its just far to stiff. Looking at poss suspension change ( on a budget tho! ) has anyone tried any kits with that amount of lowering? I know if i went for a 30mm kit it would be better but dam its looks good as it is!!!
ollie
by Welsh_Andy » Thu Apr 06, 2006 7:39 pm
<!--QuoteBegin-ollie+--><div class='quotetop'>(ollie)</div><div class='quotemain'><!--QuoteEBegin-->Hi guys , my cally is lowered 60mm on standard shocks, prob is i love the look of the car but its just far to stiff. Looking at poss suspension change ( on a budget tho! ) has anyone tried any kits with that amount of lowering? I know if i went for a 30mm kit it would be better but dam its looks good as it is!!!<!--QuoteEnd--></div><!--QuoteEEnd-->
60mm on standard shocks,sheesh u asking for probs,if u lower more than 35/40mm shortened shocks are needed
u get what u pay for in the end
Welsh_Andy
by Chavtastic » Fri Apr 07, 2006 7:56 am
You mean stiff or harsh?
Stiffness is very little to do with the shocks. Stiffness is determined by the springs. If it's too stiff then you'll need softer (and therefore higher) springs. If it's harsh over bumps and doesn't ride very well then you need new shocks.
by chief » Fri Apr 07, 2006 11:21 pm
but would'nt uprated shocks be worse than standard ones??
chief
by Chavtastic » Sat Apr 08, 2006 7:30 am
<!--QuoteBegin-chief+--><div class='quotetop'>(chief)</div><div class='quotemain'><!--QuoteEBegin-->but would'nt uprated shocks be worse than standard ones??<!--QuoteEnd--></div><!--QuoteEEnd-->
If the standard ones are worn or bust, no.
If the aftermarket ones are progressive or adjustable, no.
If the aftermarket ones are badly matched to the springs, yes.
by ollie » Mon Apr 10, 2006 8:46 am
Im looking at budget kits at the mo, gmax, pi or apex any ideas? ahd gmax on my old rs turbo and wasnt impressed
ollie
by Chavtastic » Mon Apr 10, 2006 8:48 am
The Calibra GMAX springs and shocks are quite good IMO. On my 8v it made it really chuckable
by ollie » Mon Apr 10, 2006 9:05 am
Looking for a kit that dosent make the car to stiff
ollie
by Chavtastic » Mon Apr 10, 2006 9:10 am
<!--QuoteBegin-ollie+--><div class='quotetop'>(ollie)</div><div class='quotemain'><!--QuoteEBegin-->Looking for a kit that dosent make the car to stiff<!--QuoteEnd--></div><!--QuoteEEnd-->
Well get an adjustable one then! If you want good handling then that means spending money!
by Animal » Mon Apr 10, 2006 6:54 pm
You can get softer springs that are the same ride height but the softer they are the more your gonna bottom out. On my escort I had a gmax kit and then split fire things rammed in the springs to stop the tyres rubbing in the arches. It would rattle your fillings out!! [img]/biggrin.gif[/img] Handled nicely until you hit a bumpy bit of road. LOL. [img]/biggrin.gif[/img]
Users browsing this forum: Majestic-12 [Bot] and 30 guests
