help needed asap, is it safe to drive,
by blue redtop » Sat Dec 02, 2006 1:12 pm
1.
ive been looking at my probs with my abs and pad sencers today and found this( see pic) is it safe to drive as the anti roll bar (i think its that) isnt all the way in .its half way if that .:eek:
2.
any one know how to earth the pad sencers on both sides as thers not working.:frown:
3.
on the end of the abs sencer is there ment to be a metal bit as mine is all plastic,
thanks in advance
jay:)
blue redtop
by Fraz » Sat Dec 02, 2006 1:32 pm
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->1.
<!--coloro:blue--><span style="color:blue"><!--/coloro-->eh no picture..but if it is the anti roll bar bush dont look fully on the arm...should be ok to drive <!--colorc--></span><!--/colorc-->
2.
<!--coloro:blue--><span style="color:blue"><!--/coloro-->bare the wires and join ...can use a scotch lock<!--colorc--></span><!--/colorc-->
3.
<!--coloro:blue--><span style="color:blue"><!--/coloro-->all plastic apart from the actual tip of the sensor <!--colorc--></span><!--/colorc-->
thanks in advance
jay:)<!--QuoteEnd--></div><!--QuoteEEnd-->
replied above
by blue redtop » Sat Dec 02, 2006 9:04 pm
now with pics, is this safe anyone.
cheers jay
blue redtop
by Rusty_CallyT » Sat Dec 02, 2006 10:08 pm
no reason not to drive it, even if the ARB link broke apart it would upset the handling and make some noise but at normal speeds be perfectly safe
Rusty_CallyT
by tsdinos » Sat Dec 02, 2006 10:16 pm
drive it and see what happens :icon_mrgr
tsdinos
by MJ » Sat Dec 02, 2006 10:27 pm
anti roll bar links arent difficult to fit, and are cheap to buy .... but its not uncommon for an MOT test to find broken links so we've probably all used the car with them broken at one time or another! [img]/smile.gif[/img]
MJ
by blue redtop » Sat Dec 02, 2006 10:47 pm
cheers for replys.i have been driving it all day but the thing is,nothing is broke its had all new tie rod things and lower wish bones the thing is it looks as if the roll bar is slipping back out of the rubber (towards engine). there is only about 10mm in the rubber bit, just wondered what would happen if it came out.
cheers
blue redtop
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 11 guests
