help needed asap, is it safe to drive,
1.
ive been looking at my probs with my abs and pad sencers today and found this( see pic) is it safe to drive as the anti roll bar (i think its that) isnt all the way in .its half way if that .
2.
any one know how to earth the pad sencers on both sides as thers not working.:frown:
3.
on the end of the abs sencer is there ment to be a metal bit as mine is all plastic,
thanks in advance
jay:)
2.
3.
thanks in advance
jay:)
blue redtop
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->1.
<!--coloro:blue--><span style="color:blue"><!--/coloro-->eh no picture..but if it is the anti roll bar bush dont look fully on the arm...should be ok to drive <!--colorc--></span><!--/colorc-->
2.
<!--coloro:blue--><span style="color:blue"><!--/coloro-->bare the wires and join ...can use a scotch lock<!--colorc--></span><!--/colorc-->
3.
<!--coloro:blue--><span style="color:blue"><!--/coloro-->all plastic apart from the actual tip of the sensor <!--colorc--></span><!--/colorc-->
thanks in advance
jay:)<!--QuoteEnd--></div><!--QuoteEEnd-->
replied above
2.
3.
thanks in advance
replied above
cheers for replys.i have been driving it all day but the thing is,nothing is broke its had all new tie rod things and lower wish bones the thing is it looks as if the roll bar is slipping back out of the rubber (towards engine). there is only about 10mm in the rubber bit, just wondered what would happen if it came out.
cheers
cheers
blue redtop
