ABS pump and control unit thingy
by heavenly_d3vi1 » Mon Jan 22, 2007 11:45 am
are they the same on 16v and turbos?
heavenly_d3vi1
by T.F.S. » Mon Jan 22, 2007 2:05 pm
yes i believe they are
threw one out a while back..
T.F.S.
by heavenly_d3vi1 » Mon Jan 22, 2007 2:21 pm
ah good, that means i can use the one from the car im breaking [img]/biggrin.gif[/img]
heavenly_d3vi1
by T.F.S. » Mon Jan 22, 2007 2:23 pm
let someone else confirm before you get it fitted, i may be wrong
also thats a right pain to change if the 10ml nuts round off on the hydrolic lines.....
T.F.S.
by WillsToy » Mon Jan 22, 2007 2:26 pm
Pretty sure there are two types, an early type and later ,
something to do with a slant on one side, pretty sure if you searched the tech forum you would find more info
Will
WillsToy
by heavenly_d3vi1 » Mon Jan 22, 2007 2:41 pm
hmm, id best do some searching around then!
heavenly_d3vi1
by T.F.S. » Mon Jan 22, 2007 4:17 pm
<!--QuoteBegin-heavenly_d3vi1+--><div class='quotetop'>(heavenly_d3vi1)</div><div class='quotemain'><!--QuoteEBegin-->hmm, id best do some searching around then!<!--QuoteEnd--></div><!--QuoteEEnd-->
look at the one in your turbo...it should have a bosch number on the top, then check the one in your 16v
if they are the same...
T.F.S.
by heavenly_d3vi1 » Mon Jan 22, 2007 4:38 pm
ah yeah... lol
heavenly_d3vi1
by WillsToy » Mon Jan 22, 2007 10:00 pm
Hi , just read my haynes manual, only difference is pre 92 models had the abs ecu in the footwell and not fitted directly on the abs modulator in the engine bay.
So i think you should be safe if both cars are after 92 build.
Will
WillsToy
by heavenly_d3vi1 » Mon Jan 22, 2007 10:14 pm
ahh just! 16v is 93 and turbo is 96 lol
heavenly_d3vi1
by LE16 » Wed Jan 24, 2007 8:59 pm
No they are not the same at all. I learnt this lesson when trying to fit my Electronic speedo to a formerly 16v calibra se5. Best ask someone who has actually looked at this.
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
by heavenly_d3vi1 » Wed Jan 24, 2007 9:13 pm
what has the speedo got to do with abs stuff? :S
heavenly_d3vi1
by RobbieV » Wed Jan 24, 2007 9:25 pm
<!--QuoteBegin-heavenly_d3vi1+--><div class='quotetop'>(heavenly_d3vi1)</div><div class='quotemain'><!--QuoteEBegin-->what has the speedo got to do with abs stuff? :S<!--QuoteEnd--></div><!--QuoteEEnd-->
ABS sensors are used to calculate the road speed [img]/smile.gif[/img]
Users browsing this forum: Majestic-12 [Bot] and 14 guests
