power steering
power steering
by jay_se5 » Mon Feb 26, 2007 9:47 pm
im leaking power steering fluid,,,, gonna look in the morning,, but where's the most likely place they leak?
jay_se5
by bodgetastic » Tue Feb 27, 2007 1:01 am
Most likely directly over the puddle on the floor :icon_mrgr
Get someone to put the steering on full lock and check from underneath where it is leaking from, should be very easy to see.
Could be from anywhere but for the fun of it i'll put bets on the rack :icon_pale
by jay_se5 » Tue Feb 27, 2007 9:44 am
cheers, ill let u know if your bet is right,,lol
jay_se5
by bodgetastic » Tue Feb 27, 2007 6:06 pm
Well ??
If you have any probs, give me a shout and i'll try and pop over and have a looky !?
by Defiance » Wed Feb 28, 2007 8:01 pm
All pas units i've had leak or seen leak are the seals hidden under the rubber gators on the pas rack itself
Repair kit Original vx number is NLS so epc says use 90398968
If you can post the part # off the rack if it is leaking from there and also if possible the Ident (usually yellow label with letters on eg : CY or DG/CZ/CV/DH etc) i can get a price from my parts department
Ciao
Def
Defiance
