power steering
power steering
im leaking power steering fluid,,,, gonna look in the morning,, but where's the most likely place they leak?
jay_se5
All pas units i've had leak or seen leak are the seals hidden under the rubber gators on the pas rack itself
Repair kit Original vx number is NLS so epc says use 90398968
If you can post the part # off the rack if it is leaking from there and also if possible the Ident (usually yellow label with letters on eg : CY or DG/CZ/CV/DH etc) i can get a price from my parts department
Ciao
Def
Ciao
Def
Defiance
