ABS sensor
ABS sensor
I have a abs sensor that needs to be replaced is there any visual way to tell which one i need?
antobroko
No, not unless its smashed to bits (sometimes they are)
you will need to unplug each one and measure the resistance with a multimeter. you can then get a good idea which is dead.
but on a 93 you should be able to read the fault codes anyway. that will tell you which is wrong. have a read on topbuzz.co.uk I can't recall if it has just ecu fault codes or abs too. but its same system, just different pins, you should find all you need between that site and a search on here.
Users browsing this forum: Bing [Bot] and 5 guests
