ABS sensor
ABS sensor
by antobroko » Sun Apr 08, 2007 9:20 pm
I have a abs sensor that needs to be replaced is there any visual way to tell which one i need?
antobroko
by Stupink » Sun Apr 08, 2007 10:42 pm
No, not unless its smashed to bits (sometimes they are)
you will need to unplug each one and measure the resistance with a multimeter. you can then get a good idea which is dead.
but on a 93 you should be able to read the fault codes anyway. that will tell you which is wrong. have a read on topbuzz.co.uk I can't recall if it has just ecu fault codes or abs too. but its same system, just different pins, you should find all you need between that site and a search on here.
by Fraz » Sun Apr 08, 2007 11:17 pm
here you go
<a href="http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm</a>
