Roling
Roling
Stil aint got a clue wat discs i got! Took it to the dealers ant the closest are vw corado and mariva! No other 4studs in 280, turns out the omega pads i had are the same as calibra turbo, so mayb my calipers are to!
Anway, thought id replace the pads for now hopefuly be ok,
So got the pads, went home cleaned my abs sensor because my abs light is on. Thought id put the car on and turn the wheel, see if it stays off and my front wheel was roling! And abs light came on! Wdf is that about?
Sweet calibra 16v
