Roling
Roling
by Sweet calibra 16v » Fri Jun 08, 2007 12:02 am
Stil aint got a clue wat discs i got! Took it to the dealers ant the closest are vw corado and mariva! No other 4studs in 280, turns out the omega pads i had are the same as calibra turbo, so mayb my calipers are to!
Anway, thought id replace the pads for now hopefuly be ok,
So got the pads, went home cleaned my abs sensor because my abs light is on. Thought id put the car on and turn the wheel, see if it stays off and my front wheel was roling! And abs light came on! Wdf is that about?
Sweet calibra 16v
by Rusty_CallyT » Fri Jun 08, 2007 11:09 am
if jacked up the front wheels will spin with the clutch up even out of gear as the fluid is thick enough to move the gears, theres next to no torque tho, you'll be able to stop it with a hand (if out of gear)
Rusty_CallyT
by Sweet calibra 16v » Fri Jun 08, 2007 12:04 pm
Thanks rusty, thought my car was goin mad!
I would but havnt got the time at mo.
If my abs sensors wasnt workin would they of shown on the paperclip test? Is there anyway of working out wat my abs fault is?
Sweet calibra 16v
