When did they change turbo brakes?
by Stupink » Thu Nov 29, 2007 9:15 pm
Got my old J-reg 92 struts with disks/calipers etc on it.. they have koni and eibach on them, so i want that on my scrapper.
Thinking the easiest way is to swap the lot. but not the calipers that way i dont have to bleed the brakes.
But then remembered early ones had a different brake setup by a few MM..
the scrapper is a K reg, i think a 93.
The disks from the J reg are nicer disks so i'd rather swap the disks, but will they match the calipers on the kreg or will i need to keep the kreg disks/calipers?
I'm not going to be doing the job at home, hence asking first before i strip the car down and find i need extra bits i didnt bring.
by tazz666 » Thu Nov 29, 2007 9:57 pm
just try changing the caliper calipers
tazz666
by tazz666 » Thu Nov 29, 2007 9:58 pm
that should of been caliper carriers
tazz666
by RobbieV » Thu Nov 29, 2007 10:05 pm
Early are 284mm and late 288mm and i think the change over was around the face lift time 95/96ish.
by Stupink » Thu Nov 29, 2007 10:12 pm
Ahh.. hopefully you're right robbie, I havnt measured them, but i just looked at them by eye next to eachother, as much as you can with one on the car still with wheels on etc. they looked the same.. but i had it in mind that it was pretty much only the first spec 92's that had smaller brakes.. unless there were 3 changes, which i dont think there were.
sounds like if i just drop the lot downt he workshop i should be able to mix and match anyway and chuck something on there.. worse case scenario is just spending a few more mins and splitting the struts to swap the inserts/springs anyway lol.
by RobbieV » Thu Nov 29, 2007 10:20 pm
Just checked V6Calibra.com and it states there that V6/Turbo brakes were improved from 284mm to 288mm in 1996.
by Stupink » Thu Nov 29, 2007 10:52 pm
woo.. nice one. cheers robby, sounds promising for a straight swap then :)
by Rusty_CallyT » Fri Nov 30, 2007 12:18 am
yeah changed pretty much on the facelift
Rusty_CallyT
by Phantom » Sat Dec 01, 2007 6:20 pm
I'd agree with the T chassis change as on mine someone has put 284mm disks on so when the pads wear they curl over the edge of the disk and scrape
by Stupink » Sat Dec 01, 2007 6:44 pm
well no problems, swapped the fronts over today. direct swap as predicted cheers guys :)
Just got to do the rears next dry day, clean it up and get some new tyres on it. then its all finished. actually looking like a propper car again! lol.
