When did they change turbo brakes?
Got my old J-reg 92 struts with disks/calipers etc on it.. they have koni and eibach on them, so i want that on my scrapper.
Thinking the easiest way is to swap the lot. but not the calipers that way i dont have to bleed the brakes.
But then remembered early ones had a different brake setup by a few MM..
the scrapper is a K reg, i think a 93.
The disks from the J reg are nicer disks so i'd rather swap the disks, but will they match the calipers on the kreg or will i need to keep the kreg disks/calipers?
I'm not going to be doing the job at home, hence asking first before i strip the car down and find i need extra bits i didnt bring.
Ahh.. hopefully you're right robbie, I havnt measured them, but i just looked at them by eye next to eachother, as much as you can with one on the car still with wheels on etc. they looked the same.. but i had it in mind that it was pretty much only the first spec 92's that had smaller brakes.. unless there were 3 changes, which i dont think there were.
sounds like if i just drop the lot downt he workshop i should be able to mix and match anyway and chuck something on there.. worse case scenario is just spending a few more mins and splitting the struts to swap the inserts/springs anyway lol.
