Rear Brake rattle
Rear Brake rattle
Has anyone had rear brake rattle that sounded like someone beating a tin can with a spanner... and what is the cure?
.. only happens going over driver side bumps and stops with light brake pressure ( starting to feel relieved in the wallet as I thought it was the shock... and I have already removed the heat shields).
Thanks in advance!
Thanks in advance!
kdchorse2
