Rear Brake rattle
Rear Brake rattle
by kdchorse2 » Tue May 13, 2008 9:41 pm
Has anyone had rear brake rattle that sounded like someone beating a tin can with a spanner... and what is the cure?
.. only happens going over driver side bumps and stops with light brake pressure ( starting to feel relieved in the wallet as I thought it was the shock... and I have already removed the heat shields).
Thanks in advance!
kdchorse2
by ROG » Tue May 13, 2008 11:33 pm
Have you checked the antirattle springs on the rear pads,
mine were missing, had rusted away, it sounded like something serious was wrong, rattles all the time over bumps etc, loud clicks/clunk when braking
ROG
by bodgetastic » Tue May 13, 2008 11:40 pm
Yea, mine had virtually rusted away too
by Phantom » Tue May 13, 2008 11:49 pm
you can buy the new spring a pin kit from Vauxhall
Phantom
by kdchorse2 » Wed May 14, 2008 7:25 am
Thanks folks.... off to Vauxhall tomorrow for the kit in that case.
kdchorse2
by Lee Johnson » Wed May 14, 2008 8:47 pm
have a look to see if they r loose mine did :x
Lee Johnson
