Rear camber problem
Rear camber problem
Had a puncture on a rear nearside wheel. Went to get it changed, and noticed that the inside edge was very badly worn... peered over to the offside and same thing there.
Is the rear on a Cally adjustable, though? What could be causing such dire tyre wear, and how to remedy it?
Cheers,
R
Cheers,
R
Rob Himself
Re: Rear camber problem
You can get adjustable camber kits for these as i did on my old Cav GSI. Bigger wheels and a lowering kit plays havoc with these cars
Markp
Rob, theres, two very large bushes on the front mounting bracket for the rear assembly, take a look at these and see is there perished or worn, if so replace they can be got from auto vaux for 17.50 each...
RAINMAKER
and i was thinking the same as you
fingers crossed mate
