Rear camber problem
Rear camber problem
by Rob Himself » Wed Sep 24, 2008 5:25 pm
Had a puncture on a rear nearside wheel. Went to get it changed, and noticed that the inside edge was very badly worn... peered over to the offside and same thing there.
Is the rear on a Cally adjustable, though? What could be causing such dire tyre wear, and how to remedy it?
Cheers,
R
Rob Himself
by vinny_69 » Wed Sep 24, 2008 5:30 pm
how much is yours dropped by rob?
by Rob Himself » Wed Sep 24, 2008 5:39 pm
That's the thing...
....it's not.
Rob Himself
by vinny_69 » Wed Sep 24, 2008 5:45 pm
how long you had it rob? because when i got mine a few months ago mr man swapped the fronts with the rears [-( and i was thinking the same as you
by Rob Himself » Wed Sep 24, 2008 5:47 pm
Oh.... it's possible then. Had it since June-time... I'll give it a month so, and watch how they wear... THEN start getting worried!!!
Rob Himself
by vinny_69 » Wed Sep 24, 2008 5:49 pm
all it took was two new fronts and tracking job done \:D/ fingers crossed mate
by splinter » Thu Sep 25, 2008 12:08 am
Mine was 35mm drop and my fronts wore out before my rears everytime.
Untill my tx box went bang .
Re: Rear camber problem
by Markp » Sun Jan 25, 2009 9:05 am
You can get adjustable camber kits for these as i did on my old Cav GSI. Bigger wheels and a lowering kit plays havoc with these cars :(
Markp
by RAINMAKER » Sun Jan 25, 2009 2:14 pm
Rob, theres, two very large bushes on the front mounting bracket for the rear assembly, take a look at these and see is there perished or worn, if so replace they can be got from auto vaux for 17.50 each...
RAINMAKER
