Need a new rack, but which one?
by MadOnVaux! » Wed Nov 12, 2008 6:11 pm
Guys, (and Gals ;))
Ive just been told my steering rack is on its way out (It had a slight leak advised at last MOT, and its got slightly worse)....garage says its OK to drive aslong as i keep an eye on the fluid, but it will fail next years MOT when the time comes in April, so deciding to get it done now.
I plan buying an exchange rack from www.buypartsby.co.uk , but they have 4 listed, (although the last one is a quick rack which im not bothering with),
so i have 3:
ZF Type Splined Pinion
Saginaw Type Plain Pinion
ZF Type Plain Pinion
Even my garage didnt really know, as they said they couldnt find a ZF badge on mine and wouldn't be able to tell really until the rack is off.
So, i crave your knowledge to help me, any idea which one of the above 3 i will need please?, car is a 1995 16v XEV model.
Thanks in advance :)
by MadOnVaux! » Sun Nov 16, 2008 5:25 pm
Anyone??
by RobbieV » Sun Nov 16, 2008 5:27 pm
No idea !
would it be worth ringing vaux with your chassis number for info ?
by tazz666 » Sun Nov 16, 2008 8:37 pm
i have a spare rack going
tazz666
by Naz » Mon Nov 17, 2008 1:19 pm
Defintely stay away from the ZF type as ther have an alluminum rack, this wears quicker than the non ZF type.
Naz
by MadOnVaux! » Mon Nov 17, 2008 5:18 pm
Robbie - That would be an idea i suppose, ta.
Taz - Cheers for the offer, the 2nd off of a rack ive had actully, but given the size of job it is to remove and fit another, id rather go down the new/recon route, thanks though.
Naz - Hmm, so the Saginaw one could be possible then?
by bodgetastic » Tue Nov 18, 2008 1:07 am
Give these guys a buzz, I have used them a few times and very knowledgeable. Saginaw is apparently the better rack which is what I have but not sure that would mean it fits your model.
Weston Power Steering
by MadOnVaux! » Tue Nov 18, 2008 6:09 pm
Cheers Bodge :)
Re: Need a new rack, but which one?
by MadOnVaux! » Sun Feb 08, 2009 1:05 pm
Righty, after some further investigation from myself and my garage and from what i've seen on a website, it appears i have the ZF rack with the plain pinion....can anyone confirm this is the type that would be fitted to my year of Calibra please?
by tazz666 » Sun Feb 08, 2009 1:08 pm
pm me your chassis number and i will get back to you mate
:D
tazz666
by MadOnVaux! » Sun Feb 08, 2009 4:05 pm
tazz666 wrote:pm me your chassis number and i will get back to you mate
:D
PM on its way mate cheers :)
by Richiem » Sun Feb 15, 2009 9:16 pm
This may or maynot help but the zf rack has a different connection for the columb than the other type!
If you have a zf fitted you will need to replace with the same type ..
Had mine replaced last year and found this out when i did the job.
Got a recon unit in exchange for mine at a local steering center for £150
I fitted it myself at home.
Theres a very hard to reach bolt underneath the brake servo that gave me some agro, but otherwise i did the job ok at home.
by MadOnVaux! » Thu Feb 19, 2009 5:48 pm
Cheers for help peeps, new rack arrived today, getting fitted next Tuesday all being well :)
Bit of a bargain too i reckon, £68.95 delivered, and they dont want the old one back :)
by MadOnVaux! » Sat Feb 28, 2009 5:53 pm
Its actually going in THIS Tuesday to be fitted :)
Does anyone know if i'll feel a difference in the steering or not with this rack fitted?...Its not as if mine feels slack or owt as it is.
by MadOnVaux! » Wed Mar 04, 2009 3:54 pm
All done and dusted, and it feels superb actually, deffinately feel a difference....feels more smooth and precise, plus it only came to like £190 all in...happy chappy :)
Only thing is my steering lock isnt working now, so im off back to let them have a look later.
