Need a new rack, but which one?
Guys, (and Gals
Ive just been told my steering rack is on its way out (It had a slight leak advised at last MOT, and its got slightly worse)....garage says its OK to drive aslong as i keep an eye on the fluid, but it will fail next years MOT when the time comes in April, so deciding to get it done now.
I plan buying an exchange rack from www.buypartsby.co.uk , but they have 4 listed, (although the last one is a quick rack which im not bothering with),
so i have 3:
ZF Type Splined Pinion
Saginaw Type Plain Pinion
ZF Type Plain Pinion
Even my garage didnt really know, as they said they couldnt find a ZF badge on mine and wouldn't be able to tell really until the rack is off.
So, i crave your knowledge to help me, any idea which one of the above 3 i will need please?, car is a 1995 16v XEV model.
Thanks in advance
so i have 3:
Thanks in advance
Give these guys a buzz, I have used them a few times and very knowledgeable. Saginaw is apparently the better rack which is what I have but not sure that would mean it fits your model.
Weston Power Steering
Re: Need a new rack, but which one?
Righty, after some further investigation from myself and my garage and from what i've seen on a website, it appears i have the ZF rack with the plain pinion....can anyone confirm this is the type that would be fitted to my year of Calibra please?
pm me your chassis number and i will get back to you mate
tazz666 wrote:pm me your chassis number and i will get back to you mate
PM on its way mate cheers
This may or maynot help but the zf rack has a different connection for the columb than the other type!
If you have a zf fitted you will need to replace with the same type ..
Had mine replaced last year and found this out when i did the job.
Got a recon unit in exchange for mine at a local steering center for £150
I fitted it myself at home.
Theres a very hard to reach bolt underneath the brake servo that gave me some agro, but otherwise i did the job ok at home.
Cheers for help peeps, new rack arrived today, getting fitted next Tuesday all being well
Bit of a bargain too i reckon, £68.95 delivered, and they dont want the old one back
Its actually going in THIS Tuesday to be fitted
Does anyone know if i'll feel a difference in the steering or not with this rack fitted?...Its not as if mine feels slack or owt as it is.
All done and dusted, and it feels superb actually, deffinately feel a difference....feels more smooth and precise, plus it only came to like £190 all in...happy chappy
Only thing is my steering lock isnt working now, so im off back to let them have a look later.
