inner cv boot
inner cv boot
guys i noticed before taking mine for a mot that the inner driveshaft boot is slightly leaking , is it a case of buying a new boot ,undoing old boot and replacing new boot without taking driveshaft out..or so ive heard,
inner cv boot
Baz this thread is over a year old have you been on the drink
Re: drive shaft/cv boot
Shaft needs to come out the G box Baz.
Not a hard job.
Not a hard job.
Baz this thread is over a year old, why didnt you just start a new thread
in answer to your question though if its the inner boot the driveshaft needs to come out. its easier taking the driveshaft off to do either of the boots anyway
youll need to drop the lower ball joint so you can pull out the shaft then take the boot off find the circlip and pop off the cv joint so you can put new boot on
ok sorry guys lol thanks for the help tho
have you got it fixed ? do you need any more help mate its not a hard job just a messy one
probably sort it next month , take it to a cheap garage i use for my mot , especially as its coming winter
could you not have a go at it your self with some help from the guys local to you ?
maybe callyman and a few other might be up for helping but next week i have to sort out some debts back to these guys 1st and then i will see how things go then , i have to get my balancing sorted this week too. and the next time i see you steve yum yums will be coming your way lol
its a doddle to replace the boot Baz and yes its a dirty job but its easy peasy
vinny_69
Re: inner cv boot
its a inner CV boot so it just pulls out from the gear box...or with a wee bit help from a leaver sometimes needed ...just be aware that you will also have gear oil spilling out, so you best have some new stuff ready
Re: inner cv boot
oh its the inner one
i did the old mans corsa while it was still in the gearbox as i couldnt get the bugger out.
i did the old mans corsa while it was still in the gearbox as i couldnt get the bugger out.-
vinny_69
Re: inner cv boot
Vinny, on a corsa (and a few other VX's for that matter) You can remove the driveshaft complete from the car with only removing the hub nut.
