inner cv boot
inner cv boot
by BazV6er » Sat Sep 25, 2010 11:06 pm
guys i noticed before taking mine for a mot that the inner driveshaft boot is slightly leaking , is it a case of buying a new boot ,undoing old boot and replacing new boot without taking driveshaft out..or so ive heard,
inner cv boot
by v6 steve » Sat Sep 25, 2010 11:11 pm
Baz this thread is over a year old have you been on the drink
Re: drive shaft/cv boot
by Callyman » Sat Sep 25, 2010 11:12 pm
Shaft needs to come out the G box Baz.
Not a hard job.
by Allys Cally » Sat Sep 25, 2010 11:14 pm
Baz this thread is over a year old, why didnt you just start a new thread :roll:
in answer to your question though if its the inner boot the driveshaft needs to come out. its easier taking the driveshaft off to do either of the boots anyway
by v6 steve » Sat Sep 25, 2010 11:15 pm
youll need to drop the lower ball joint so you can pull out the shaft then take the boot off find the circlip and pop off the cv joint so you can put new boot on
by BazV6er » Mon Sep 27, 2010 11:21 am
ok sorry guys lol thanks for the help tho :alright:
by v6 steve » Mon Sep 27, 2010 11:25 am
have you got it fixed ? do you need any more help mate its not a hard job just a messy one
by BazV6er » Mon Sep 27, 2010 11:37 am
probably sort it next month , take it to a cheap garage i use for my mot , especially as its coming winter
by v6 steve » Mon Sep 27, 2010 11:38 am
could you not have a go at it your self with some help from the guys local to you ?
by BazV6er » Mon Sep 27, 2010 12:13 pm
maybe callyman and a few other might be up for helping but next week i have to sort out some debts back to these guys 1st and then i will see how things go then , i have to get my balancing sorted this week too. and the next time i see you steve yum yums will be coming your way lol
by vinny_69 » Mon Sep 27, 2010 3:57 pm
its a doddle to replace the boot Baz and yes its a dirty job but its easy peasy
Re: inner cv boot
by vinny_69 » Mon Sep 27, 2010 4:07 pm
and good set needle nose required for the worst bit :mrgreen: the poxy c clip
Re: inner cv boot
by Fraz » Mon Sep 27, 2010 4:20 pm
its a inner CV boot so it just pulls out from the gear box...or with a wee bit help from a leaver sometimes needed ...just be aware that you will also have gear oil spilling out, so you best have some new stuff ready
Re: inner cv boot
by vinny_69 » Mon Sep 27, 2010 4:25 pm
oh its the inner one :think: i did the old mans corsa while it was still in the gearbox as i couldnt get the bugger out.
Re: inner cv boot
by Callyman » Mon Sep 27, 2010 5:42 pm
Vinny, on a corsa (and a few other VX's for that matter) You can remove the driveshaft complete from the car with only removing the hub nut. :whistle:
Users browsing this forum: No registered users and 64 guests
