anyone bought these? discs
by stevo turbo » Wed Feb 09, 2011 7:18 pm
http://cgi.ebay.co.uk/Calibra-Turbo-Dri ... 19b868da03
if so are they any good? if i buy them i will be using a set of green stuff pads with them
Re: anyone bought these? discs
by RobbieV » Wed Feb 09, 2011 7:29 pm
Used Mtec on the last three V6's that ive owned and never had any problems with them, Make sure you get the right rear discs from Mtec as they are confused over what the Calibra uses :)
by Allys Cally » Wed Feb 09, 2011 7:31 pm
ive just bought a set of front ones Steve, and i will be sticking some greenstuff pads on mine as well.
by stevo turbo » Thu Feb 10, 2011 8:45 pm
excelent, cheers
by KERR_SE9 » Thu Feb 10, 2011 9:14 pm
I've just put these allround on my turbo, yet to drive it though, so can't comment on how good they are, damn good price though
by Vxlgsi » Thu Feb 10, 2011 10:33 pm
standard pads are better than green stuff
Vxlgsi
by stevo turbo » Fri Feb 11, 2011 6:56 pm
Vxlgsi wrote:standard pads are better than green stuff
how comes? care to expand on that please?
by Mark1 » Fri Feb 11, 2011 7:03 pm
I've got Tar-ox on mine.
by Callyman » Fri Feb 11, 2011 7:12 pm
I've been told that too.
Can't remember why tho. :roll:
by Allys Cally » Fri Feb 11, 2011 7:14 pm
the fact that my standard pads heat up and fade very quickly under heavy braking is the main reason for going with a better pad.
by Callyman » Fri Feb 11, 2011 7:28 pm
Allys Cally wrote:the fact that my standard pads heat up and fade very quickly under heavy braking is the main reason for going with a better pad.
It that on a solid/grooved/drilled disc?
by Allys Cally » Fri Feb 11, 2011 7:33 pm
right now i have solid vented discs, but i have a set of drilled/grooved discs to go on Andy
by Callyman » Fri Feb 11, 2011 7:37 pm
That will be half the reason they are fading Ally, when i went to drilled and grooved on std pads, there was a real difference once bedded in.
by Allys Cally » Fri Feb 11, 2011 7:42 pm
yes i know solid discs were crap even more so after i cooked then on the highland tour last year. plus i'm using the car everyday now after i sold the 8v. and lets just say i'm not afraid to drive my car in anger on a daily basis :mrgreen:
by v6 steve » Fri Feb 11, 2011 8:38 pm
std pads are only better till the disc heats up then the green stuff will out do it hands down, green stuff can take a lot more heat than std ones can, now iv got video of my pads somking and part of the video showing how bad the brake fad was, my older not as good looking brother used to race at knockhill and used red and green stuff pads and never once had them smoke, he did say that red stuff are very scary when there cold so never used them on the road but found the green stuff the better
