anyone bought these? discs
http://cgi.ebay.co.uk/Calibra-Turbo-Dri ... 19b868da03
if so are they any good? if i buy them i will be using a set of green stuff pads with them
- Club Member
Re: anyone bought these? discs
Used Mtec on the last three V6's that ive owned and never had any problems with them, Make sure you get the right rear discs from Mtec as they are confused over what the Calibra uses
ive just bought a set of front ones Steve, and i will be sticking some greenstuff pads on mine as well.
excelent, cheers
- Club Member
I've just put these allround on my turbo, yet to drive it though, so can't comment on how good they are, damn good price though
Vxlgsi wrote:standard pads are better than green stuff
how comes? care to expand on that please?
- Club Member
I've got Tar-ox on mine.
stevo turbo wrote:Vxlgsi wrote:standard pads are better than green stuff
I've been told that too.
Can't remember why tho.
the fact that my standard pads heat up and fade very quickly under heavy braking is the main reason for going with a better pad.
Allys Cally wrote:the fact that my standard pads heat up and fade very quickly under heavy braking is the main reason for going with a better pad.
It that on a solid/grooved/drilled disc?
right now i have solid vented discs, but i have a set of drilled/grooved discs to go on Andy
That will be half the reason they are fading Ally, when i went to drilled and grooved on std pads, there was a real difference once bedded in.
yes i know solid discs were crap even more so after i cooked then on the highland tour last year. plus i'm using the car everyday now after i sold the 8v. and lets just say i'm not afraid to drive my car in anger on a daily basis
std pads are only better till the disc heats up then the green stuff will out do it hands down, green stuff can take a lot more heat than std ones can, now iv got video of my pads somking and part of the video showing how bad the brake fad was, my older not as good looking brother used to race at knockhill and used red and green stuff pads and never once had them smoke, he did say that red stuff are very scary when there cold so never used them on the road but found the green stuff the better
