ABS sensor.........
NO you won;t need to. As you say, the ABS is not attched to the disk. Even the ABS ring itself is not part of the disk and its part of the hub. But if you change the hub, for example from 4 stud to 5 stud, then you might need to change the sensor as well as it MIGHT be diff.
hope it helps
hope it helps
Naz
