ABS sensor.........
by diamondcali » Sun Aug 22, 2004 12:51 pm
Hi all,
can anyone please tell me the answer to this question please ??
When you change the front discs for bigger ones,do you have to disconnect
the abs sensor ??
I`m pretty sure you don`t as the sensor is attached to the strut is it not ??
Cheers,
Andy.
diamondcali
by Naz » Sun Aug 22, 2004 5:22 pm
NO you won;t need to. As you say, the ABS is not attched to the disk. Even the ABS ring itself is not part of the disk and its part of the hub. But if you change the hub, for example from 4 stud to 5 stud, then you might need to change the sensor as well as it MIGHT be diff.
hope it helps
Naz
by diamondcali » Sun Aug 22, 2004 7:00 pm
Yep,
just as i thought....
thanks for the info.
Andy.
diamondcali
