4 stud to 5 stud
4 stud to 5 stud
Ok guys what do i need to change from 4 stud to 5 stud can i just change hubs and nothing else or is there more to it
'Once Driven Forever Smitten'
Re: 4 stud to 5 stud
You can change just the hubs, Just get the correct bearings for the hubs.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
DanSE4 wrote:You can change just the hubs, Just get the correct bearings for the hubs.
Cheers Dan that's all i need to no perfect
would be easier to change the rear arms rather than doing the rear hub
What he said. If you can pick up a complete set of front legs & rear arms with 5 stud hubs then just swap them over, saves having to press the hubs out of your existing ones.
DanSE4 wrote:If you can pick up a complete set of front legs & rear arms with 5 stud hubs
Thanks easier said than done these days
