4 stud to 5 stud
4 stud to 5 stud
by BigDaz » Mon Apr 04, 2016 9:34 pm
Ok guys what do i need to change from 4 stud to 5 stud can i just change hubs and nothing else or is there more to it
'Once Driven Forever Smitten'
Re: 4 stud to 5 stud
by DanSE4 » Tue Apr 05, 2016 1:56 pm
You can change just the hubs, Just get the correct bearings for the hubs.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
by BigDaz » Tue Apr 05, 2016 8:54 pm
DanSE4 wrote:You can change just the hubs, Just get the correct bearings for the hubs.
Cheers Dan that's all i need to no perfect :handgestures-thumbupleft: got a chance of some turbo fan blades so was needing to no what i would need to change
by v6 steve » Tue Apr 05, 2016 9:54 pm
would be easier to change the rear arms rather than doing the rear hub
Club Admin
Club Admin
by DanSE4 » Wed Apr 06, 2016 4:09 pm
What he said. If you can pick up a complete set of front legs & rear arms with 5 stud hubs then just swap them over, saves having to press the hubs out of your existing ones.
by BigDaz » Wed Apr 06, 2016 4:28 pm
DanSE4 wrote:If you can pick up a complete set of front legs & rear arms with 5 stud hubs
Thanks easier said than done these days
