Steering Wheel Vibration over 60mph
AndiSe5
could be youve got a slight buckle in your wheel so slight youl hardly be able to notice it visually i had same problem with mine luckily i work at kwik fit so every day when i had a spare min i pulled mine in & kept re-balancing them as i didnt notice any buckles on the balancer in the end i swapped my wheels front to back & the vibrations have stopped try swapping them if it still shakes it could be warped discs but that would cause a bad vibration through braking
wilko
as ianw sed then it could possibly be the disc isnt flat on the hub tak4e the discs of & get a wire brush & clean the hubs where the discs sit a neighbour of mine had a simlar prob with his sierra every time he had the brakes stripped unless he scrubbed the hubs with a wire brush making sure the surface woz like new he came accross problems also check how the tyres are wearing if there not wearing even 1 could be out of shape which could also cause a vibration
wilko
<!--QuoteBegin-sophos9+--><div class='quotetop'>(sophos9)</div><div class='quotemain'><!--QuoteEBegin-->Andi, can you post up a list of things you have tried?<!--QuoteEnd--></div><!--QuoteEEnd-->
Oh yes.
Ok my car had originaly 17's and the standard breaks when the wobble started.
Since then i have bought new alloys, new disks pads and calipers (308mm conversion) also at that time i clean the hub.
Recently i changed the lower wishbones, the drop linqs and the outer cv joints and also the topmount bushes including the bearings.
And today i ballanced the wheels again.
There is no play in the bearings.
The only other thing i can think of is the shocks ?
Oh yes.
AndiSe5
Jeez, what a list?!?
Ok, the vibration....
Is it between a certain speed range
Is it on different road surfaces
Is it more more noticable on acceleration or deceleration
Is it noticible on braking
Have you had a good curbing or smack in the front?
At this point, I would suspect a bent or distorted driveshaft but let me know the answers
sophos9
<!--QuoteBegin-sophos9+--><div class='quotetop'>(sophos9)</div><div class='quotemain'><!--QuoteEBegin-->Jeez, what a list?!?
Is it between a certain speed range - 55mph and 65mph
Is it on different road surfaces - no
Is it more more noticable on acceleration or deceleration - no
Is it noticible on braking - no, bracking is solid.
Car has hit no curbs tracking is stright.
Wish i had changed the whole drive shafts now [img]/sad.gif[/img]
The problem occored one day when i had taken the previous wheels off for a good clean.
Ever since then its wobbled, but not as bad now as it did as it had when the problem started.
AndiSe5
<!--coloro:black--><span style="color:black"><!--/coloro-->I've just started to have the same problem - steering wheel vibration over 60mph. Plus, it gives a slight pull/'kick' every now and again, as if the car is about to go off to one side (it doesn't, thank God!).<!--colorc--></span><!--/colorc-->
<!--coloro:black--><span style="color:black"><!--/coloro-->Had the wheels balanced a year ago. Now wondering whether a more thorough diagnosis and treatment is needed. <!--colorc--></span><!--/colorc-->
<!--coloro:black--><span style="color:black"><!--/coloro--><!--fonto:Times New Roman--><span style="font-family:Times New Roman"><!--/fonto--><!--fonto:Verdana--><span style="font-family:Verdana"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Typical timing, as am planning to drive up to Cambridge this weekend… [img]/sad.gif[/img]<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--><!--fontc--></span><!--/fontc--><!--colorc--></span><!--/colorc-->
RichardH
Users browsing this forum: Google [Bot] and 8 guests
