power steering reservoir (noob)
So where is it located on a 16v ecotech [img]/smile.gif[/img]
Think it may be low out of fluid!
Also anyone seen that Haynes manual I bought and flicked through once and not seen it in over a year?
colic
try tapping the top of it gently a few times , also try turning with your other hand, the one on my lorry wont open unless i use my left hand, havent got a clue why, must be the angle the force is on?
my old cav wouldnt open, even after tapping the top a bit, eventualy i tapped the top around with a small hammer and a pc of wood only took one tap and it would then undo ( if you tap it the right way! )
ROG
