Sticky rear caliper.
by Mac » Fri May 13, 2005 2:36 pm
When car is left for a few days, when you start driving you can here a rubbing/grinding noise from the rear right wheel station. This noise goes away after 10 mins or so. Thought it might be shoes for hand brake but it also happens now and again if you are using yer brakes alot/hard ( for fast B roads and things). Also I have noticed The wear pattern on the disc is quite thin compaired the the other side,
Ant thoughts on this problem??
Cheers.
Mac
by Robert_Dale » Fri May 13, 2005 3:18 pm
mate they need a service thats all, cos its been standing still it will be binding.
Take the brake pads out and replace em if poss or sand the sides down to release them.
Robert_Dale
by Mac » Fri May 13, 2005 3:50 pm
Cheers, Will the new pads be ok with the wear pattern on the disc or will it kill em' quick??
Havin' probs with yer Fly?
Mac
by Robert_Dale » Fri May 13, 2005 4:08 pm
yeh mate, probs best to replace the back disks as well mate, but if you can release em they might wear a bit better??
the fly never fit mate [img]/sad.gif[/img] was for an 8v and the fella thought it was a 16v.....gutted is not the word
Robert_Dale
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
