top strut mounts
top strut mounts
by Mace » Sat May 21, 2005 3:15 pm
Just removed the front suspension on the cally as i am returning it to standard to find the top strut mounts are completely wrecked, the middle fell out when i chucked them on the floor:roll: ... is there a place to get cheapy ones online, moneys tight this month and i need it back on the road..
Mace
by icewizard » Sat May 21, 2005 6:06 pm
what part do you need I've got some spare.
icewizard
by Mace » Sun May 22, 2005 12:01 pm
I need two top strut mounts the black rubber bush with the metal plate in it?
Mace
by BenW » Sun May 22, 2005 2:42 pm
Vauxhall charge about 50 quid each side btw. I need to do one of mine too [img]/sad.gif[/img]
BenW
by Mace » Sun May 22, 2005 3:15 pm
I rang my local motor factors, 16.99 a side.. no too bad
Mace
by AndiSe5 » Sun May 22, 2005 5:59 pm
Yeah i got mine from Autovaux, there not cheap eh.
AndiSe5
by Mace » Wed May 25, 2005 3:18 pm
Removed the shocks and found the cause... when you push the shocks in they were jamming solid when they were hardly pushed in at all??? unlike the new ones which are smooth.. never had that before.. caused it to smash through the strut mounting.. could have been dangerous if it broke all the way through... wasent far off either..
Mace
by 4x4Turbo » Thu May 26, 2005 2:39 pm
sorry to hi jack this post!!!
but are these the ones because i need to change mine aswell
<a href="http://www.autovaux.co.uk/StockItem.asp?AVCode=AVSS&AVNo=122&cat=51&carID=57" target="_blank">http://www.autovaux.co.uk/StockItem.asp?AV...cat=51&carID=57</a>
4x4Turbo
by Mace » Thu May 26, 2005 4:18 pm
Yes thats the top strut mount, but the bearing can sometimes go which is seperate..
Mace
