Fuel Computer Bulb
Fuel Computer Bulb
by SukySaggi » Mon May 30, 2005 1:35 pm
Mines blown:( and needs to be changed, but where is it? I removed the computer but all its got in the back is the big yellow plug. Can anyone help?
SukySaggi
by Fraz » Mon May 30, 2005 2:12 pm
IIRC you have to undo the four small screws holding the computer together to get to the bulb
by SukySaggi » Mon May 30, 2005 2:31 pm
Thanks Fraz, will do. Can I get a red bulb from ultraleds to replace the original bulb. If I can can someone tell me what one I need to order.
Thanks.
SukySaggi
by RobbieV » Mon May 30, 2005 2:57 pm
On the side of the fuel computer you will see a small white plug, pull it off and you will see the bulb, just use a small pair of tweezers and pull the bulb out. [img]/smile.gif[/img]
by Tim2001 » Mon May 30, 2005 3:42 pm
Suki if you want a red bulb remind me next time uyour at hook or if your coming upto Santa pod this weekend.
Tim2001
