will they fit
will they fit
by BazV6er » Tue May 31, 2005 3:51 pm
if i put the original tyres onto my alloys (205/60/15) will they be better grip than my 195/50/15s as all of the tyres arent the same .I was thinking of changing the original ones from the gsi alloy type will they be okay?
by jaybv6 » Tue May 31, 2005 9:24 pm
For starters you will be fitting the wrong size tyre if you fit the 205/60r15's. The correct tyre for the 15" wheels (both on the Calibra and GSI Cav) is 205/55r15. If you are running 195/50r15's at present then thats the wrong size also as if you are running a 195 cross section you shoulod be on 60 profile tyres and not 50 i.e. should be 195/60r15's.
Anyhow, a 205 cross section wheel will give better grip due to the increased contact patch with the road. The lower profile will also help with stability aswell.
jaybv6
by trev150 » Tue May 31, 2005 9:35 pm
20/55/15 will be the best choice.
by BazV6er » Tue May 31, 2005 10:07 pm
sorry guys i think you are correct they arent 205/55/15
