Clunking and clinking sound from the front right
Hi guys,
Well, my cali problems are persisting at a scary rate now.
I've got a worrying clunking and clinking sound coming from the front right of the car. Sounds like it could be the wheel/suspension area as it only happens when going over bumps.
Any ideas?
Any ideas?
ZeroRisk
If it's the ARB link, I paid £20 + pennies for one this morning from a Vauxhall dealer. There are two types, and as yours is a '94 car, I'd guess yours will be the earlier push-on type. They are a right git to change apparently...but I've never done it as mine are the later bolt-on type.
Anyhow! To see if that's the problem, take a look and see if the roll bar is physically connected to the lower arm - if not, it needs a new link. A very common failure.
BenW
Hi Cally, I haven't had the shox changed. Everything is standard on the car except my front brake discs. Which, I might add, the right disc has some sort of yellowy-brown stuff baked on....
I was reading on the Topbuzz website that if the CV boot splits then it splashes the grease over the driveshaft and braking system. Could this be yet another problem? [img]/sad.gif[/img]
ZeroRisk
Ive just acquired this same problem! From the front right aswell.
Seems to have happened over night.
Im a complete novice with mechanicking, is the roll bar link easy to see/change?
Mine seems only to clunk when I turn left, or hit a bump.
As long as its not dangerous it can wait till payday.
Peruzzi
wishbone bushes might only be 4 pound, ive tried fitting them into the wishbone, far easier to but a wishbone with the new joint on it , new bushes in it and get the antirollbar link at the same time , i got 2 wishbones and antrolbar links for 50 pound and its all done , if you only fit new bushes, the other bits can fail at any time as the bushes have worn the other bits have had more wear as well.
ROG
