Clonking Noise
Clonking Noise
by wardyworld » Thu Jun 16, 2005 6:12 pm
Hello all,
Have discovered that if I turn right above 5 mph, there is a loud Clonk noise, doesn't seem to affect steering - just makes a loud "Clonk" and then all is well again.
Im sure someone else must have experienced this...
any ideas what it is? Im crap with mechanics and just wanted to ask before I take it to a garage and get shafted!
Cheers,
wardyworld.
wardyworld
by ROG » Thu Jun 16, 2005 6:27 pm
anti roll bar link probably or wishbone bushes
ROG
by lammy » Thu Jun 16, 2005 6:34 pm
Had similar on mine..now its either a ball joint/trackrod end/wishbone problem?..I thought..had them checked by a mate and all ok!...I then painted my front callipers and thought i'd clean and spray a load of WD40 on the top and bottom of the springs, the noise has gone now now.....try that..however you should get the suspension joints/bushes checked out too as there could be a serious problem that will cost more money in the future if you don't sort it.
SE9
by johnny_adidas » Fri Jun 17, 2005 11:57 am
its more than likely your ball joint. mine does the same. im getting a complete wishbone though as from reading on here its easier just to swap the whole part. i got both wishbones for 51 ster inc delivery to ireland on ebay
johnny_adidas
by wardyworld » Fri Jun 17, 2005 12:35 pm
Cheers for the replies -
At least I now have something to go on - and hopefully wont get shafted when I take it to the garage...
wardyworld
by BenW » Fri Jun 17, 2005 12:59 pm
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->its more than likely your ball joint. mine does the same. im getting a complete wishbone though as from reading on here its easier just to swap the whole part. i got both wishbones for 51 ster inc delivery to ireland on ebay<!--QuoteEnd--></div><!--QuoteEEnd-->
You're right, changing just the balljoint can be a total pain.
I've got a 'clunk' from the n/s too, it's been there for months. So far I've replaced the shocks (both sides obviously), balljoint, arb link (which was missing anyway!) and the noise is still there.
My wishbone bush is completely shot on that side so with luck, that's what's causing the noise. I probably also need a new top mount on that side too, according to a mechanic mate of mine. Something else to consider?
BenW
by wardyworld » Fri Jun 17, 2005 4:43 pm
<!--QuoteBegin-BenW+--><div class='quotetop'>(BenW)</div><div class='quotemain'><!--QuoteEBegin-->You're right, changing just the balljoint can be a total pain.
My wishbone bush is completely shot on that side so with luck, that's what's causing the noise. I probably also need a new top mount on that side too, according to a mechanic mate of mine. Something else to consider?<!--QuoteEnd--></div><!--QuoteEEnd-->
Cheers for this too - I hate nothing more than replacing a part to drive off and find the same problem carries on!
I'll pass all this info onto a trusted mechanic who's done my cars for years - it should help him diagnose and fix it quickly from this info.
cheers guys.
wardyworld
by Welsh_Andy » Mon Jun 20, 2005 12:54 pm
i have same prob,but replaced the whole wishbone and link end replaced but still there, any other ideas what mine could be:confused:
could it be as result of using 18's
Welsh_Andy
by wardyworld » Mon Jun 20, 2005 7:00 pm
<!--QuoteBegin-welsh_cally_man+--><div class='quotetop'>(welsh_cally_man)</div><div class='quotemain'><!--QuoteEBegin-->i have same prob,but replaced the whole wishbone and link end replaced but still there, any other ideas what mine could be:confused:
could it be as result of using 18's<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi welsh_cally_man,
Well - could be - I fitted 18s a few months back and this noise started about a week ago!!!
Im booking it into a garage tomorrow to see what they think. I will NOT be happy if they replace something and the noise is still there!
Cheers,
wardyworld.
wardyworld
by Welsh_Andy » Mon Jun 20, 2005 8:27 pm
the other thing it could be is the front strut,but my koni kit is brand new,unless tis fecked already as im running them on hardest setting,and wouldnt be amuzed if it was fecked:no:
Welsh_Andy
by mfw898y » Thu Jul 07, 2005 8:57 pm
My anti roll bar mount sheared yesterday and had same symptoms. Cheap fix.
mfw898y
by Noel » Fri Jul 08, 2005 5:17 pm
Could also be your spring, I have had this ever since I lowered it. Nothin to worry bout, its just the spring hiting the stop in the spring cup. Only usually does it when you go from one lock to the other.
Noel
