computer fitting.......
by blue_v6 » Wed Jul 06, 2005 9:42 am
hi guys i just purchase a trip computer to go on my v6 cali but i cant find the yellow plug lead which goes in the back of the trip computer any ideeas where can i look for it?thanks
blue_v6
by Dan Willis » Wed Jul 06, 2005 9:44 am
Usually taped to the firewall/bulkhead directly behind the clock area.
Dan
by blue_v6 » Wed Jul 06, 2005 9:46 am
<!--QuoteBegin-willisit+--><div class='quotetop'>(willisit)</div><div class='quotemain'><!--QuoteEBegin-->Usually taped to the firewall/bulkhead directly behind the clock area.<!--QuoteEnd--></div><!--QuoteEEnd-->
i can see the normal lead from the original digital clock but i cant see the yellow one?i should do a deep search?
blue_v6
by callymental » Wed Jul 06, 2005 9:48 am
Mine took quite some finding. Was taped to the bottom of the stereo hole. All the way to the front.
callymental
by se6 » Wed Jul 06, 2005 3:52 pm
Mine was just behind the clock. If you take the glove box out its not at all difficult to get at.
by blue_v6 » Wed Jul 06, 2005 4:17 pm
<!--QuoteBegin-se6+--><div class='quotetop'>(se6)</div><div class='quotemain'><!--QuoteEBegin-->Mine was just behind the clock. If you take the glove box out its not at all difficult to get at.<!--QuoteEnd--></div><!--QuoteEEnd-->
yes after 1 hour i find mine aswell,but i know it sounds stupid but could u tell how do i read all them stuff(aver.cons.,speed,range) or maybe im stupid:oops:
blue_v6
by STEVA » Wed Jul 06, 2005 4:20 pm
Did you get the switch with the fuel computer if not thats what you need
by blue_v6 » Wed Jul 06, 2005 4:23 pm
<!--QuoteBegin-STEVA+--><div class='quotetop'>(STEVA)</div><div class='quotemain'><!--QuoteEBegin-->Did you get the switch with the fuel computer if not thats what you need<!--QuoteEnd--></div><!--QuoteEEnd-->
yes i got the switch aswell fitted...........i mean i dont know to read them numbers
blue_v6
by STEVA » Wed Jul 06, 2005 4:36 pm
Ah right silly me!!! :oops:
aver cons is your miles to gallon, range calculates how may miles you have left in your tank, aver speed calculates youur average speed!
by blue_v6 » Wed Jul 06, 2005 4:40 pm
<!--QuoteBegin-STEVA+--><div class='quotetop'>(STEVA)</div><div class='quotemain'><!--QuoteEBegin-->Ah right silly me!!! :oops:
aver cons is your miles to gallon, range calculates how may miles you have left in your tank, aver speed calculates youur average speed!<!--QuoteEnd--></div><!--QuoteEEnd-->
well on the average speed it started with 1 and finished on 13 when i stop the car?how do i read that?what them numbers mean because miles cant be?
blue_v6
by STEVA » Wed Jul 06, 2005 4:45 pm
Not to sure about the speed mines the same doesnt seem to work properly either might need calibrating
