Rear reg plate light
by c1emm » Sun Jul 31, 2005 9:02 pm
my rear reg plate light isnt working and ive changed the bulb but still not working, all the other lights are working as they should,
Could the actual unit itself be stuffed and need replacing or could it be something else ???
thanks for any help [img]/smile.gif[/img]
forgot to mention is was for the omega!
c1emm
by Smurf » Sun Jul 31, 2005 9:06 pm
Fuse? I'm not sure which it'd be, but it'll be run off one.
Smurf
by Rusty_CallyT » Sun Jul 31, 2005 9:08 pm
is it both or 1 of em? mine works but then doesnt but will come back on with a tap
Rusty_CallyT
by c1emm » Sun Jul 31, 2005 9:14 pm
its on the omega adam, they only have the one light
c1emm
by Rusty_CallyT » Sun Jul 31, 2005 9:24 pm
ahh right lol, got a multimeter/voltmeter? might be worth checking theres voltage to the unit
Rusty_CallyT
by SukySaggi » Mon Aug 01, 2005 12:37 pm
Did you check with the side lights on?
SukySaggi
by Phil69 » Mon Aug 01, 2005 2:40 pm
If any of the contacts have corroded like they did on mine then there won't be a good enough conduct of electricity. Check it and if needbe, either clean it up or replace it....you could get a cheapy for 1 or 2 quid from the breakers.
Failing that, check the wires to make sure there are no breaks in them.
by c1emm » Tue Aug 02, 2005 12:10 am
suky havent checked with just side lights on only main headlights
Phil, i will get that checked and hopefully its just summit stupid
thanks for the replys tho guys
c1emm
