Lowering
Lowering
by tonycalibra » Fri Aug 05, 2005 9:28 am
Springs or full kit?
Trying to decide how to go about some lowering. I'm running on 16's with 55mm tyres and am not planning to go any bigger. Not sure whether to do it just on springs or go for the full kit. I've got the cash now to get the spring kit and I'm an impatient sod.
Anybody got any advice? How much should I pay to have the kit fitted?
tonycalibra
by Col » Fri Aug 05, 2005 7:14 pm
I went to several garages asking if they would fit my kit. Some didnt want to know, some wanted £150, £200 etc etc
In the end I found a garage who did the full job for £80 so shop around I say
Col
by tonycalibra » Mon Aug 08, 2005 8:40 am
Did you lower on just springs or the full kit?
tonycalibra
by chas27 » Mon Aug 08, 2005 1:53 pm
[U]BE WARNED
I ordered a set of lowering springs from a company called PERFORMANCE FX it was advertising on e-bay.
I ordered on 20 july and still havent received em they quoted "out of stock" as an excuse.
Yet they still advertised em as 24 hr delivery.
chas27
by Dan Willis » Mon Aug 08, 2005 1:54 pm
<!--QuoteBegin-tonycalibra+--><div class='quotetop'>(tonycalibra)</div><div class='quotemain'><!--QuoteEBegin-->Did you lower on just springs or the full kit?<!--QuoteEnd--></div><!--QuoteEEnd-->
Full kit. Springs alone can make the car "see saw" and generally handle badly.
Dan
by Lucifer » Mon Aug 08, 2005 7:12 pm
lowering springs offer only looks and a stiffer ride, nothing more nothing less. But because the shock absorber is not designed to work with a 30/40mm lowering spring then the suspension travel will end up soon.
To have a proper suspension you need to change and the shocks as well to suit with the lower springs.
B
Lucifer
by dj centrino » Mon Aug 08, 2005 8:39 pm
I have found this! I only went for the springs and KNOW that i need to upgrade the shocks, the only problem is getting hold of the darn things for the V6, no one sells them!!
I have found that many extras, wheels etc are sold for the V6 and the Turbo, however the lowering springs for my car came boxed as the turbo springs but i am sure that the V6 is heavier at the front, Bonus is it looks great nice and low!!! The shocks do need addressing as the the back is like a boat, have seen threads talking about the nylon bushes helping out but where can i get V6 shocks (lowered car) from??
Cheers,
dj centrino
by Rosh » Tue Aug 09, 2005 4:42 pm
koni adjustables for sure. the calibra turbo and v6 are the same fitment
rosh
Rosh
by dj centrino » Tue Aug 09, 2005 9:44 pm
Cheers, will look. Later
dj centrino
by Chavtastic » Wed Aug 10, 2005 4:00 am
I drive my car quicker round the bends than most... and I'd say 60mm springs on standard shocks is best.
