Powerflex bushes, camber correction
by joeraz » Sat Aug 13, 2005 4:50 pm
The cav/ cally 4x4 rear trailing arm bush`s,,
I have bought these but i am :confused: as the ones i have say
2 per car - 2 in this pack,, as in 2 pairs (2 bushes per pair)
but some sellers are listing these for the cally at 4 needed per car?
I am :confused:
also paid top dollar,, was also charged for 2, i did not think they could sell them per pair of bushes(one side)
Help
joeraz
by Animal » Sat Aug 13, 2005 5:07 pm
I think you just need one each side.
Dunno if you've seen this.
by joeraz » Sat Aug 13, 2005 5:24 pm
I see what ur saying but im still :confused: as this page
<a href="http://www.powerflex.co.uk/products.asp?cat=0036&catalog=0936&submit1.x=20&submit1.y=15" target="_blank">http://www.powerflex.co.uk/products.asp?ca...20&submit1.y=15</a>
says u need 4,, but im guessing its meaning 2 bushes per side,,
and this shows u a pic
<a href="http://www.powerflex.co.uk/images/pdf/0936.pdf" target="_blank">http://www.powerflex.co.uk/images/pdf/0936.pdf</a>
the product i hav contradicts its self as it says 2 per car, and there site for the same product says 4 per car
i bought PFR80-440 MLK
joeraz
by Animal » Sat Aug 13, 2005 5:35 pm
They both say 4 per car from wot I can see. Unless I'm looking in the wrong place.
by Animal » Sat Aug 13, 2005 5:37 pm
"All bushes are part numbered and priced individually but need to be ordered in pairs
For example, Front outer track control arm bush = two per car"
Could that have anything to do with it?
I found it on the bottom of the site
by joeraz » Sat Aug 13, 2005 5:44 pm
lets see if i can explain this,,
the bushes i got,, there are 4 of them, 4 halfs,, 2 halfs to make 1 bush, so 2 complete bushes, one for each side
so i only have 2 complete bushes, but that pic says i should have 4 complete bushes,, well the part No. that i bought anyway,, ?
confused
If i only need 1 bush per side i will shut up [img]/biggrin.gif[/img]
joeraz
by joeraz » Sat Aug 13, 2005 11:16 pm
<!--QuoteBegin-Animal+--><div class='quotetop'>(Animal)</div><div class='quotemain'><!--QuoteEBegin-->I think you just need one each side.
Image<!--QuoteEnd--></div><!--QuoteEEnd-->
i got these,, 2 complete bushes, so only 1 per side:confused:
joeraz
by Chavtastic » Sun Aug 14, 2005 1:15 am
Might save your transfer box but it doesn't do the handling and favours IMO.
by CAL.16V » Sun Aug 14, 2005 9:06 am
if the car is lowered you need 2 sets so 4 bushes and if not then you need 1 set or 2bushes
CAL.16V
by joeraz » Sun Aug 14, 2005 9:30 am
<!--QuoteBegin-CAL.16V+--><div class='quotetop'>(CAL.16V)</div><div class='quotemain'><!--QuoteEBegin-->if the car is lowered you need 2 sets so 4 bushes and if not then you need 1 set or 2bushes<!--QuoteEnd--></div><!--QuoteEEnd-->
ok, but what am saying is,, 1 set = £99 ?????
Car aint lowered yet
joeraz
by Cheater2k » Tue Aug 16, 2005 8:58 pm
what do you need the camber corection for then?? lol, do it with your suspension.
Cheater2k
by joeraz » Tue Aug 16, 2005 10:19 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->what do you need the camber corection for then?? lol, do it with your suspension.<!--QuoteEnd--></div><!--QuoteEEnd-->
erm, maybe because my rears have worn bald on the inside
joeraz
by CAL.16V » Thu Aug 18, 2005 7:14 am
thats hell expensive then.....
have a look on
<a href="http://www.ebay.com.au" target="_blank">www.ebay.com.au</a> and type in calibra
theres a guy selling noltec camber bushes for $85 a pair or 35 pounds a pair and postage would be 5-10 pounds
CAL.16V
by Cheater2k » Thu Aug 18, 2005 9:55 am
If its not lowered, and the cambers out, theres somthing else wrong mate, so your missing the point completly.
Its either your wishbones, or suspension struts, maybe even a suspension spring snapped.
Check all these first.
Cheater2k
by Welsh_Andy » Thu Aug 18, 2005 12:12 pm
i think i ave camber prob,on 18's lowered 40mm offset 40,,seems to be running on the inside of the tyre,and a bit of a handful in the wet, would a camber correction do the job for me,what sort of time would it take a decent mechanic,as tis not a job i would tackle
Welsh_Andy
