Alarm - windows roll up
Right then, M reg calibra.
Unlocks and lock, also windows roll up
Now, on my old calibra (N reg) i could just shut the windows and not lock the doors, now when i press button 4 to roll the windows up, it locks as well, any ideas?
(Toad AI606)
(Toad AI606)
Cheater2k
Was it the same alarm set-up? Otherwise it sounds like the alarm's got a lock feed and a separate pull-down to ground (for the windows) that fire at the same time. You'd have to check the alarm fitter's manual probably to find out if you can separate the two feeds to two buttons.
Does what I just said make sense? I dunno.
jimbohotpants
