Pulls to one side during braking....
The topic pretty much says it all....
New Pads, Rotors are ATE oval slotted... only about 6,000 miles on them. What could be causing the trouble?
King Calibra
Just had the car run through inspection, to include a brake test. It passed with flying colors. Only about 6% difference between Left and Right braking forces. Any other suggestions? Would it be the bushings possibly? It also jerks to one side during hard acceleration, and wobbles terribly around 60mph.
I just had it up on a lift about a week ago, and I noticed that the sway bar has been totally disconnected from the left front lower arm. (I went under to check because I hear a loud "bang" when I go over bumps sometimes.
I also get loud popping when I turn the wheel, and the power steering is giving me problems. (I'm in pretty bad shape, huh?)
King Calibra
